1 - 2 of 2 Posts
I have a Kitchen-aid KSSS48qjw00
I understand that it is real similiar to whirlpool refrigerators.
The icemaker is not working. I test the power between L-N and there is no voltage at all. I remove the icemaker and test the connector and still no power. What do I need to test next?
on the frz wall side did you check where black and white would go>120vac. if ok I/M bad, also that harness has a line fuse in it that may have popped. I/M comes with new harness. if not, this gets techie, you should call local servicer.
1 - 2 of 2 Posts
