1 - 20 of 25 Posts
Model - KichenAid KSRS251KWH03. 6 years old. It's a side by side, when it is making ice cubes, there a motor noise and it sounds like it's working extra hard..almost a grinding sound, but it does make ice. the water dispenser flows very slowly (I don't get water from the refreigerator anymore). This noise goes on daily.:(
Does anyone know what this noise is? It's been going on for about 9 months now. The refriegerator stays cold 40 degrees and the freezer seems to be okay too
Hi,
Nope since we cannot hear it for ourselves.
Fill valve buzzzzzing from low water pressure??
Think the noise is more inside the refrigerator or outside of the refrigerator?
Poor/low pressure fills...clogged shut off valve ( esp self piercing style ), bad fill valve, tired filter, kinked line.
jeff.
Yes, I did change the filter. But, the noise never went away. I was thinking that it was a problem with the supply water, but not sure bc of the noise. It sounds like it's working extra hard.
Thanks for any helpful tips on this.
refrigerator ice maker problem
I did check the water line, but didn't notice any kink (it's been a while). I'll double check again.
I curious about what the cause of the motor noise could be.
Thanks for all the good tips,
Discussion Starter · #13 ·
that is a good possibility that the noise is from the ice maker head. Next time, I hear the noise get up and listen to the door or I'll open the freezer and hope to hear it that way.
Thanks
· Commercial Flat Roofing
This is a strange thing.
Mine groans, rather annoying. It happens when an ice cube gets stuck during the dump of the cubes.
One of the separators was damaged a while ago and every once in a while it starts to moan, groan, creak etc I have to pull a cube out and the noise goes away.
First time posting here, great forum folks!
I have the same problem as the original poster. Fridge: 2004 Kenmore (Whirlpool) 106.7xxxxxx series. The ice maker makes ice and cubes do not get caught in the mechanism.
I made a recording of the noise with my Pocket PC but there's no way to upload it to the forum... I would best describe it as a creak or groan. If anyone here saw the movie "The Grudge" it sounds very similar to the guttural throat noise made by the poltergeist children in the haunted house.
The noise comes from the gear pictured in the link jeff1 posted above that says "Do not rotate manually" on it. As the gear rotates back and forth slowly, it makes the creaking/groaning sound. When the plastic cover is removed and the gear is exposed, it is obvious that the sounds correspond with the gear movement.
The sound can be heard throughout the house when the house is quiet. Does anyone have a suggestion for quieting the ice maker?
G'day,
Full model# would have been best to post.
Sounds like ( no pun intended ) the motor on the module...
Whirlpool icemaker repair module
jeff.
Thanks for the reply Jeff, I was hoping it'd be you that responded. It may be too little too late, but the full model # is 106.73182302.
Can the motor be repaired with some proper lubrication & maintanence? If not, I can get it fixed for free with an appliance insurance plan I get through my gas supplier. I enjoy DIY, that's why I ask. :)
Also OT, but do you know if this fridge uses a water filter? I can't find mention in the owner's manual or online. Thanks,
--Mahstah
Likely can quieten it down for a bit with some lube, but the motor is not available seperetly and if the insurance will pay for a new part....let them.
None built into the refrigerator itself.
Only filter it may have is an add on inline filter in the supply water line feed.
jeff.
Good to know, because the fridge currently has the cheap translucent plastic hose and I recently purchased a real feed line to replace it. A plumber friend told me that if the cheap hose breaks it's major, and they tend to break over time. I think I'll splice a filter into the new line. Thanks again for the info.
--Mahstah
1 - 20 of 25 Posts
