Whirpool Refrig Ice maker. The water filter plugged up and after replacing the filter the ice maker would not fill up the tray. I put water in the tray and it made ice and shedded the ice but would not refill the tray.
not enough info.. did you use an OEM filter? off label stuff can be problematic. refrig came with a filter by-pass. try that, to narrow prob down. may have bad valve or blocked i/m feed line[ice in tube].
#1 HAWKEYE FAN
did you purge the filter to get all the air out?
