1 - 9 of 9 Posts
I am considering a floor tile that is made of recycled Polyvinyl for my garage. I found it at Lowes. The pictures look great, but I want to know if it is as easy to install as the sales guy said it was.
It's called Flexi Tile, I want the coin pattern (the one with the circles).
Polyvinyl flooring tend to be on the lower end of price scale, and they come in a wide range of colors and styles which can mesh with an assortment of design schemes. The resources at suntouch floor warming make even to think in a wide range.
Flexi-Tile
Well, I went for it and went to the Lowes near my house and had to special order the Flexi-Tiles. I picked them up Friday and installed the whole garage in about 2 1/2 hours. The tiles were very heavy. That was the hardest part, the install was easy. It took a day for the the seams to settle. It was a little pricey, but they look great. Even my wife thought they looked cool.
PVC vinyl flooring
I have a small sound studio. I installed the PVC Polyvinyl tiles under the stage floor and through out the board room. I have found it is great for absorbing the sound and it can handle all the heavy equipment that comes in and out each day. Called the manufacture and they said it was static resistant, which is why I chose it over carpet.
I got it at Home Depot online. Tried to special order it, but you can only get it on the web. Just as well the stuff is heavy. The brand was called ITtile I picked this brand because it came with a lifetime warranty.
Hi All,
I ordered 1 box of 7mm Commercial black to test and examine before placing my full order. I put 2 pieces together as per the instructions and as a test poured a small amount of water on the joint between the 2 pieces. After letting it sit for only a minute or 2 I examined the underside and saw that the water had indeed seeped through.
I know that the Reflex site states that the tiles are mold\mildew resistant, but what will happen if I install this across my garage floor and experience a spill? The underside of the tile is flat and rests fully on the underlying substrate which means any spills will sit and have no route to escape or evaporate.
I love this solution over epoxy b\c I can take it with me if I move and it provides a much better surface to stand on for long periods as opposed to bare concrete.
However, I don't feel comfortable knowing that if I spill any liquids they'll settle under the tile and stay there for...ever? I guess a solution would be that when I do have a spill I'd have to pick the effected tiles up, address the spill and re-seat the tiles? Not a fun prospect but I guess no solution is perfect.
Thoughts?
1 - 9 of 9 Posts
