Follow directions, usually 24-48 hrs is good. Vacuum and wipe with a tack rag to get up dust and stuff.
I just finished using a oil based minwax stain on my floor. How long do i need to let it cure and do i need to do anything before i apply the water based poly finish.
I second the last post. I don't know why you are applying a water base over an oil base. You may have problems with the water base adhering. Don't the directions on the can say not to do this?
