Hi all,
I recently purchased my first home and pulled up carpets to find (mostly) gorgeous hardwood floors in need of refinishing.
The catch is that there are several spots with oddities that I'm not sure how to handle prior to having them sanded and polyurethaned. I'm looking for any bright and creative ideas for how to improve the situation.
Pictures are here:
Issue 1 -
The original owners removed four fireplaces throughout the house and replaced the hearth area with non-flooring wood pieces that are roughly the same width as my original hardwood but a different color. These are pictures 1-3 on the link above.
What are my options? Can the flooring guy treat it the same way as the rest of the floor (sand and poly)? Should I try to have him mix up a stain to match the rest of the wood? What about any ideas in the way of putting a non functional fireplace with a nice hearth back in the place of the old ones?
Issue 2 -
There are multiple spots where the original flooring is currently patched either because holes (~1 inch diameter) were drilled or just because of large gaps. How do I handle that prior to having the flooring guy come in? Picture 4 in link.
Issue 3 -
There is one section where they apparently pulled up a floor board and it is now loose with wide gaps between two boards. Do I have to have the flooring guy replace them alltogether? Any other ideas?
Picture 5 in link.
Issue 4 -
There was some settlement around the load bearing wall on the first floor. The hardwood adjacent to the wall has cracked significantly. Is that just something I keep as-is and chalk up to character in a 90 year old house, or is there an efficient way to deal with it?
Picture 6 in link,
I appreciate any feedback you can give on the above issues!
A first time homeowner.
Pictures are here:
Issue 1 -
Issue 2 -
Issue 3 -
Picture 5 in link.
Issue 4 -
Picture 6 in link,
