I have worked with the siding before, beautiful, but it does require much maintenance. If they are thick enough I would recommend sanding them, although you are looking at a big job.
When you reapply the new stain, since you have a large area to cover, use the roller. I like to let the wood soak up the stain a little before continue.
If it is a huge job I would recommend contracting the work out. If you don't have a whole lot of time on your hands, it could be worth your while.
Jason
Jason
