Greetings all,
I just repainted a room and one thing that I've also been meaning to fix up are the air registers. I wanted to replace them, but the screw locations on the Lowe's and Menard's 10"x6" registers are off by about half an inch.
All the ducts were put in when the house was built in the late 50s, so it's probably an older mounting standard?
Anyhow, perhaps the only way would be to just strip off the many layers of paint (probably a few with lead) on it, and respray it with one good coat of white.
I'm using a product called Motsenbocker's Lift Off Paint & Varnish Remover. That should get it down to the bare metal.
I think it's made of iron or steel? I should prime it as usual, and spray?
Also, I should be able to use your standard Krylon spray paint? I shouldn't need to worry about hot air melting the paint when winter rolls around?
I don't think the hot air gets hot enough to warrant the use of Krylon Hight Heat and Radiator spray paint?
