I have a real mess to deal with. First, I live on a barrier island on the Gulf of Mexico. Following hurricane Ivan, we added a wrap around deck using pressure treated lumber, with "choice deck" decking, and pressure treated materials for the railings. Although I used sst screws for the decking, I followed not very good advise, and used treated deck screws for the railings. Being a retired carpenter, I built the deck. I did hire a professional painter to do the original finishing. Now, 5 years later, the treated deck screws are literally failing due to corrosion, and spindles have fallen off. And, the finish is failing big time. It is apparenty paint,not stain
I decided to reahilibate rather than replace, so I have used a rust converter to treat the screws, a least thoes I could not remove, fill all holes, replace the damaged spindles, and renail all spindle and rail tops using sst ring shank nails. Now I need advise on the re-finshing. Should I pressure wash to remove loose paint, salt, and dirt? Should I then sand to bare wood where possible? Or, as some have suggested, DO NOT pressure wash since it tends to drive contaniment into the wood surface. If not, what other choices are preferred?
