Hello all. I recently used a 3/4" Sharbite tee to tap into my 3/4" copper hot and cold water supply lines to run water to a new bathroom. After making the modification, the water pressure to the shower - only a foot or so downstream of the new Sharkbite tee - has noticeably less pressure. I figured maybe the Sharkbite didn't install correctly, so I cut out a couple feet of the copper and put in a section of 3/4" pex (connected to the existing copper on each end with a Sharkbite) with a brass crimped tee for the supply to the new bathroom. Still crappy pressure. The water supple to the new bathroom is shut off with valves, so that shouldn't have anything to do with it.
I'm at a loss. It obviously has to be something related to the work I just did, but I've never had an issue with Sharkbites causing noticeably reduced pressure. The only other thing I can think of is - possibly - the gate valve that I used to shut off water to the whole house before the repair could have gone bad and is not opening all the way.
Any ideas here? Could tapping into 3/4" copper with a Sharkbite tee cause this? If so, I guess I would need to get a plumber to come put copper back in (I can't sweat copper). Thanks for the advice.
