I'm looking to lay down new flooring (3/4" hardwood, 4 1/4" wide planks) in my house (built in 1945), and I know that the subfloor needs to be redone first as there are certain rooms with multiple dips of up to 2 inches, and all sorts of 'wavyness'. The current flooring is parquet, and this is visible to the naked eye.
Anyhow, I started tearing up the flooring in one room to see how bad the situation is. The parquet isn't coming off cleanly, so I've been lifting up the (damaged) 3/8" plywood beneath it. Beneath that, it looks like I'm down to the original subfloor, which is 3/4" x 7" planks laid at an angle (20 degrees off perpendicular, maybe?) to the joists. This planking is relatively weak as you feel (and see) it flexing when you walk across it. The joists are 2" x 10", and look to be in good shape, although they're surely off level. They are spaced at 20".
So, what would be the recommended sub-flooring to put in? I was originally planning on ripping up the planks, shimming the joists (maybe sistering the worst offenders), and laying down 3/4" T+G plywood. However, isn't such a floor normally laid on joists that are spaced at 16"? Should my subfloor be thicker because of the wider joist spacing?
Also, one of the walls in this room is a load bearing wall (running perpendicular to the joists). Since the wall was built on top of the old subfloor, I know I'll need to reinforce underneath it as I take up the old subfloor (I want to minimize movement of the wall, and subsequent plaster fixups). I was planning on going joist by joist, and putting in little lengths of 2" x 10" between the joists, under the wall. Is this sufficient? What is the best way to attach these?
Any response would be greatly appreciated!
Chris
Chris
