Master Bedroom ceiling has a large (10 foot) crack running perpendicular to the ceiling joists. This is a recurring problem that happens over and over for the last 20 years.
The crack runs about half way across the master bedroom ceiling. I/others have repaired it with both Paper and Tape, and neither has held. I have done other cracks with great success, so I do not believe that my technique was to blame.
I do not know how to immobilize the joists above (or if that would even be a good idea). The only other thing I can think of is an expansion joint.
I searched this forum, and found that it may also be known as a "Vinyl Expansion Joint".
1) I have googled "Drywall Expansion Joint" and see that there are some products out there, but I have not read people's experience with it. How was the installation, and how has it lasted? How does it look?
2) The crack currently runs 1/2 way across the room. Should I install the expansion joint just in that area, or all the way across the room.
3) How do you finish the joint? Do you leave it exposed? Add a cover? Spackle/Prime/Paint?
Any feedback would be deeply appreciated.
Thank you.
Thank you.
