We installed 4 new recessed lights in our basement. They did not replace any fixtures - we created lighting where there was previously none. Here is our process:
*We ran 4 new 6 inch recessed lights, wired to be controlled by two 3 way switches. The bulbs we purchased are listed on the outside of the "can" boxes (65 watt BR30).
*The switches are 20 amp. The circuit breaker is 20 amp.
*Power (12-2) is run to the 1st switch. 12-3 then runs from the 1st switch to the 2nd switch. 12-2 then runs from the 2nd switch to light #1. Then from #1 to #2, #2 to #3, and then lastly from #3 to #4.
*It initially worked. The lights worked, and the switches worked. For about 10 minutes. Then #2 abruptly went out. About 5 minutes later #4 began flickering for about one minute before #3 went out. We turned off the lights for about 30 minutes. Now #4 flickers continuously before going out within a few minutes, but #2 and #3 will not come back on again at all. #1 has worked thus far without flickering or going out.
*The circuit is not overloaded.
We have no idea what the problem could be. This diagram is exactly how we wired the (4) recessed lights.
