Licensed Electrical Cont.
From the switch: black to black, white to white, grounds to grounds.
If the switch is existing use whatever size wire is existing. If it is #12, use #12. If #14 use #14.
Power source======switch box=====light====light====light=====light
====== is two wire cable two wire cable w/ground, sized the same as the circuit you are tapping into.
At sw box, white to white, both blacks to switch.
At lights, color to color.
Use a plastic sw box, leave a ground pigtail for the switch.
Use a metal sw box, use a ground screw in the tapped hole and ground the box.
