How do you open outside recess lighting fixtures to chage bulb?
I have several outdoor recessed lighting fixtures on my building that need the bulbs replaced.
I googled how to do it. It said they are spring loaded and should just pop down enough so you can change the bulb.
However when I tried to do this - they do not seem that easy to pop off. I used a flatip screwdriver to try to get a hold of enough metal to pop it open - but no luck.
Is there an easy trick here. Any suggestion or weblinks would be very helpful.
Thanks in advance.
Thanks in advance.
