I really want to put recessed lighting all over the house but I figured I would play with the third bedroom/office first in case I mess something up.
The ceiling is open above by a large attic with insulation so I know i need the IC types. What else should I know, the room is about 10x12 so how many should I install and where in the room?
None of the bedrooms in the house have overheard lights, all switches are wired to an outlet so I figure the best way is to drop a wire down from the attic and wire that up to the switch box. Should I remove the outlet and just path the hole?
Any pointers on what brand, size to use? Thanks.
