Hello All,
I currently have a Master Bedroom (home built in 1990) that has a ceiling fan/light combo that is powered by two wall switches located by the door. One switch controls the fan light and the other switch controls the fan blades.
The goal is to install 4 recessed lights controlled by a dimmer switch around a new ceiling fan (no light) that is controlled by the other switch. I have attic access above the bedroom.
I removed the existing fan and was left with a ceiling wire that contains a red, black, and white wire (see picture).
The switch box contains 2 wires: one wire contains 2 white wires, 2 black wires, and 2 ground wires and the other wire is the one from the ceiling fan (red, black, and white wire) (see pictures).
Attic -
My questions -
1. What is the correct way to tap into the power source for the recessed lights? My plan is to daisy chain the lights.
2. What is the best way to supply power to the ceiling fan (again, no light)? The fan has blue, white, and black wires (see picture)
3. What else should I be thinking about? I welcome any other input.
Thank you in advance for your help/input/advice on this project!!
Attic -
My questions -
