I recently had an electrician install 6 or so recessed lights (or pot lights) in our insulated attic. I checked out the job he did and there were at least one code violation and maybe a couple more.
The first thing is that the light type wasn't IC or rated for contact with insulation. I'm going to correct this by replacing the fixtures with IC-type.
The 2 other things I had a question about whether they are legal.
1. He ran the NM cable across the bottom member of the roof trusses kind of all over the place and didn't support with running boards. They are just strung from light to light. Also, they are not perpendicular or parallel to the framing, but are running at odd angles from light to light. Is this legal? I was thinking of adding 1x4 running boards underneath the wiring so that it is supported. Can the running boards be at an angle to the framing (such as 45 degree)?
2. He ran the wiring from an existing junction box that looks like it is overcrowded with wires. Can someone point me to the formula for determining how many wires can be inside a box? Also, the box has no cover on it. Does the box in the attic (so it's accessible) need to have a cover on it?
thanks in advance!
thanks in advance!
