I need to temporarily remove some recessed light cans to gain access for running low voltage wire in the ceiling. Can anyone give me advice on removing the can by looking at the picture?
These lights were retrofitted by the previous owner, so I'm pretty sure they are not nailed to rafters. A second floor is above, not an attic. I suspect the black clips are holding it in, but I don't know how to unclip them. I've pushed them up, down, in, out, etc.
Any help would be appreciated.
· Retired Moderator
Those black things are springs that curve down and press against the drywall---stick a flat screw driver into the slot at the top and push up a bit and they should release---
goodle the instructions of a Halo recessed light---that's not a Halo but the springs are similar
