In 210.52 of the NEC 2014 code book, it discusses requirements for receptacles. I have one location that I'm wondering about though, even though I think I know the answer via the book...
Attached are a couple of photos of the interior door entrance area to a bedroom. The door is 32" wide and there is a wall 36" in length that the door will open against. Parallel to the door is another wall (a closet) which is 28" wide. The two photos show two different angles of the entrance; one from within the room, the other from outside the room.
My question concerns those two small walls. They are both 24" or greater, so I assume I will have to put receptacles in each of them. Am I right? Because it seems to be silly to put a receptacle behind a normally open door. Nothing will ever plug into it there. Same with the one on the parallel wall. Anything plugged in here would restrict access into the bedroom! But code is code...
Tom
Tom
