The room over the porch has the following problems:
The end result should be level floor joists spanning the whole room sistered to both the existing level joists and the existing sloped joists. I can throw insulation into that above the porch. On top of that I can lay new subfloor and hardwood finish.
Good strategy?
- Parts of the floor are soft--there even seems to be a hole under the carpet. Probably needs some of the subfloor replaced.
- The front half of the room slopes downward, because it's over the porch and the joists run on a slope there.
Good strategy?
