Working on a laundry room remodel, currently has a gfi for the washer.
It has a 20 amp circuit feeding a junction box, from that box feeds a total of 2 ceiling lights, the washer gfi, and a new outlet into a hallway that probably will never be used except for a night light or something.
Gets a little trickier because is actually two hots going into the junction box.
Problem is, if I connect the gfi correctly to line side, then run the other outlet in hallway on load side, trips the gfi.
My first thought was a bad gfi and replaced. Does same thing.
Now I am thinking that with 2 power feeds coming into J-box, if neutrals were tied in together, would this cause the gfi to trip like this?
Works fine on line side, just trips when adding a load to it.
Is a confusing mess inside the j-box and not sure if the neutrals are tied together ... think big blue wire nuts.
Just my best guess at this time.
Just wondering what else would cause this ... the gfi as is, has worked for the washing machine for years.
