Ok,
I'm getting a bit of this, but wanted to understand more.
I understand the black wire carries the current to the switch and then the light or the electrical outlet. Ground wire is also easy to understand as it will carry current to ground in case the black wire touches the box for example.
I had 2 questions:
1) If a black (hot) wire touches the electrical box and then travels on the grounding wire to "ground", how does this trip the breaker in the box? I don't understand how that surge would go to the box and trip the breaker that the light is on...or does it cut all power?
2) Neutral wire (white) : At a electrical outlet, the black wire provides the power...is the neutral wire also carrying this same power, basically is it as hot as the black wire? Or is it just there to return unused power back to ground once an appliance is plugged into the outlet.
As you can see, I kinda got the jist of things...but not really!
Thanks for the help!
I had 2 questions:
