Ready to tile?
2598 Views 15 Replies 4 Participants Last post by  esco5710
First off thanks to everyone that contributed to my other thread on kitchen tiling. Now that i have a better idea on the process, i want to list what i plan to do and see if Im understanding everything correctly.
I plan on removing the plywood underlayment and lay down cement board. I picked this method over the ditra cuz of price and simplicity. Someone recommended using 1/4 cement board. Since i dont know the thickness or grade of the plywood subfloor, is there any drawback going with 1/2 instead? I would assume no if theres enough of clearance for the appliances. And its not in my case. Ive read that you can use unmodified or modified thinset under the cement board? White vs grey is not important for this. As for laying the tile, i think im going with a darker grout so i should probably go with the grey modified thinset? Im still deciding on the which thinset- too many to pick from so i am asking for some recommendations. I also picked up the LASH leveling clips to help with the lippage for the 12x24 tiles. My understanding is i should use a 1/2x1/2x1/2 notched trowel to spread the tile thinset and 1/4x1/4x1/4 to spread the thinset under the cementboard. I should also backbutter the each. Im close to both bigbox stores so if someone can recommended an appropriate thinset and provide feedback on the cementboard thickness i would greatly appreciate it! Feel free to correct anything that ive stated wrong too. Thanks!
1 - 16 of 16 Posts
Backer board add not strength what so ever to the floor---use the 1/4" unless you want the extra height for some reason----
I nail floors with galvanized roofing nails---Rock screws work well but I see no added benefit on a floor---
Use a good quality modified thinset---color is up to you---
Yes to the 1/2" trowel and back buttering for the tile---
Consider renting a bridge saw and but a 4" angle grinder with a diamond blade---those are some long cuts--a smaller saw will work ,however--so use what you own.
How do you determine whats a good quality thinset?
Look for Mepei or Latacrete---Perhaps Bud or Jazman could give you an exact product name---
Price is probably the best way since we can't easily test it until you use it. You can use the cheapest thinset, even unmodified under all CBU's. Although some makers recommend modified thinset to set the boards too.
One factor whether to use two different mortars is the size of the job. No point buying both types if it's a small area. I prefer white to set tiles.
With large tiles like you're now using you should buy a medium-bed mortar. There's many brands available. One that is easy to find is Granite & Marble mortar at the orange place. Lowes carries either Mapei or Laticrete and I don't know which at your store.
Make sure the floor is very flat.
Jaz
What should i do if i cant determine the thickness or type of plywood was used for the subfloor? Will it be sufficient with the cementboard on top then the tiles? Sry if these questions seem repetitive but im trying to completely understand how it works. Thanks.
SHould not be that difficult. Dont know if you have forced air heating with heating ducts and registers but if you take the cover off the register you can usually see the thickness of the subfloor where the elbow/boot joins the register...or better yet take off a floor-located cold air return grate.
Several ways to determine the thickness. The ones mentioned may work, but often the subfloor is covered with sheet metal so you can't see without prying some away. Another way is to simply drill a small hole someplace, then measure with a tape measure or by using a headed nail held/hooked upside down.
Use 1/4" CBU unless you want to raise the floor higher. Color of grout vs. color of thinset has nothing to do with each other.
Jaz
Thanks Jazman... There's currently 1/2 plywood underlayment resting on a thin sheet of wood covering? (doesn't seem like sheet metal but could very well be that) over wood planks (home was built in the 1960s). By laying down cement board over the 1/2 plywood then tiles, the floor is raised roughly 1" 1/4 than the adjoining hallway wood flooring. Keeping the plywood seems extreme to me but I'm a novice and looking for help... Without knowing the quality of the subfloor/ joists etc, should i keep the 1/2 plywood or can I lay the cement board over the sheet metal/ planks (subfloor) then tile over the cement board which would give me a more even flooring? If the 1/2 plywood is necessary for the structure where can i find a higher saddle/ transition that would minimize the height difference? The ones Ive seen at the big box stores were 1/2" in height which would not hide the cement board/ thinset/ tiles. Thanks!
Esco, forgive me, but you're gonna hafta do better than that. If you can't tell the difference between sheet metal and wood, how are we gonna help you install this floor?
So it sounds you're saying your subfloor is planks, (are they diagonal or perpendicular to the joists?). Over that is a thin layer of ply, (is it close to 1/4"?), might be luaun underlayment for vinyl floor that might still be there or was removed). Then over that is 1/2" ply? All that could be, but doesn't sound right.
I'd like to know exactly what you've got with no guessing. Ideally you probably should remove the 1/2" and that thin ply under it to get the the plank subfloor. Inspect/repair the planks, then install 1/2" or thicker ply and then the concrete board etc.
You're concerned about the height of the two rooms but I don't think you mentioned what's on the other floor. Rooms are liable to be at different levels unless you install the same floors on them. I wouldn't be too concerned unless it's over an inch variation for residential floors. Commercial is different cuz some people are looking for a place to trip.
Jaz
Jazman, it definitely doesnt look or feel like metal but since you mentioned that was common- i assumed thats what it could be. The planks run diagonal On top of that is this very thing covering- not sure if its leftover from the previous flooring (which i dont know what that was). Then the 1/2" of plywood that had linoleum Flooring. I will try to take pics to give you a visual of the layers.
I have hardwood flooring in the hallway leading to the kitchen.
OK, so the other area is 3/4" above the planks and once you do the kitchen the way I mentioned you will be about 1/2" higher than the hardwood. (Ply, concrete board, tile). Note: you may have to install 5/8" underlayment depending on the type, size and condition of the planks.
You'll be able to install a 1/2" +- hardwood reducer over the hardwood butting within 1/8" of the tiles. Or maybe a hardwood "T" molding, or make a saddle.
Jaz
Jazman, essentially, you're suggesting I remove the thin covering/ wood piece and relay the 1/2 plywood on top of the planks? The thin piece is very thin, <1/4 I would say. Do you think it would make a noticeable difference in height? Can I use 1/4 of plywood instead to lay the cement board on then tile or is that not recommended? Thanks!
There should be no 1/4" anything in a tile installation sandwich. Regardless, I think it would be a good idea to get down to the planks and refasten/repair as necessary. Chances are the planks are not t&g and the nails may have worked a bit loose by now.
What kind of shape is the 1/2" you're looking at? What was on it? I might consider leaving what you've got, just refastening if I thought everything was in good shape and didn't mind the extra height.
But let's see what other info you give.
I said;
I was asking for an answer. Did we ever talk about the framing yet?
We went in circles a little cuz in your first post I think you went into too many subject. You asked about; plywood types & thickness, concrete board, Ditra, thinset mortars, Lash, trowels, backbuttering, and large tile sizes. We can help with all those, but not all at once. So, let's start with the joists.
Size, spacing, unsupported span to the inch. Species and grade if at all possible. Basement, crawl space?
Jaz
I said;
Jaz
The 1/2 ply is in excellent shape.. Pretty solid and level. Looks to me to be only a few years old (i bought the condo in 09) and the previous owners were only here 2 yrs. The old flooring was linoleum tile which came up easier than I expected and didn't leave much, if any, adhesive. I sanded the floor to clear up any residue.
Sry for jumping around topics. Since this is my first tiling job and a much delayed project, Im trying to get alot of info quick. Originally, I was told I could tile directly over the plywood with no problem. Then someone at the tile place suggested laying mesh over to get a better bond to the tile... which lead me to this site and research on the proper surface for tiling- and everyone was against tiling on wood.
I live on a ground floor condo built in the 60s..no basement, no crawl space. I don't know the exact dimensions or condition of the joists and subfloor. My question about the thickness was to get a better idea of the levels associated with a normal floor. As I mentioned, the height difference is pretty apparent so I wanted to know if there was a better option (i.e. cement board directly over the lowest level subfloor/ planks). This doesn't seem to be an ideal set up tho. So, the I think I will refasten the 1/2 ply which would give me more than enough support to lay the cement board then tile. I will have to figure out a solution to transition the different level of flooring. Any advise is very much appreciated!
1 - 16 of 16 Posts
