Just bought the property. It has old heavy large casement windows with heavy duty hinges. I freed the crank movement and the windows move fine. The problem is that the sash from most windows has sunk on the latch end making the sash un-square. I can push up on the corner of the sash at the latch end and the glass shifts as the end lifts square. If I square it up, I can close the window.
What are the odds of being able to square up these old sashes? I don't want to run a brace diagonal across the glass. I'm not sure angle brackets in the inside corners would hold it square.
Anyone have any experience with this? I have considered just putting double hung in there or replacing the sashes entirely but figured I'd check to see if I'm missing an easy fix.
Thank you!
Thank you!
