1 - 17 of 17 Posts
I am trying to locate a RCD auto resetting device. They are available overseas however I can't find any electricians that are aware of such devices.
They work by automatically retested an "off" RCD and if OK, will move the RCD to "on".
Any advice is appreciated.
Dean
Banned
So the device in the first link counts 3600 cycles of the 60 Hz and then tests. Probably gives a marginal increase in reliability vs. checking once/month.
Not a bad idea.
Electronics-wise this should probably add $1 or less to the cost of each GFCI, assuming the manufacturer is buying in huge lots. They have to add a 12 (16 for the second link) stage binary counter IC to the PC board.
Discussion Starter #6
Thanks for the replies.
I am located in Australia - RCD are compulsory over here. In my situation, the RCD gets triggerred occassionaly and when I visit the holiday home where its installed - the fish in the aquarium are dead and the frig is full of mould etc
The devices seem to be popular and widely used in Europe and UK from what I can gather.
Banned
You seem to want a device that decides if it tripped for a valid or invalid reason.
For houses this decision is usually made by a human with test equipment, although I think power companies have automatic reclosing circuit breakers that try several times to energize a circuit that initially caused an overload, in the hope that the fault has since cleared.
If no one makes such a device, you could make it yourself by modifying a GFCI but the details of that project are somewhat beyond the scope of this forum.
You could try electro-tech online but I'm not sure making such a device would be wise for an unoccupied house.
Discussion Starter #8
In fact when the device tripped correctly, but the cause is weather related and qucikly clears.
Our solar panels are tempermental and when rain/water contact some where, it trips. It is impossible howver to identify the panel (there are 24) and relevant cell in the panel.
" Euro " electrician
Which verison you want ?
There is a breaker and power point verison.
However the powerpoint verison is not super common but we can get it from time to time.
And what brand Customer panel or breaker panel you have there so I can able look it up.
Merci,
Marc
Ok but what brand name so I can able dail it down closer.
Just keep in your mind the European standard may be little differnt than Aussie standard but it should be pretty close with the specs.
Once you give me the brand name of that breaker box is then I can able post what model you can use.
Merci,
Marc
Discussion Starter #13
The brand on the web is GEWISS
http://www.gewiss.com/irj/portal
They have a large range of RCD Autorestters and I don't have the technical background to make an informed selection from their range and whether it is going to be compatible.
We have 3 phase with everything being standard for Australian conditions
So you need a GFCI that waits this interval of seconds, minutes or hours and then retries for a few times.
A GFCI, relay & timer will do it. If you can post the schematic of a candidate GFCI I may be able to step you through it.
This
http://www.ti.com/lit/ds/symlink/lm1851.pdf
is just one choice for the IC in the thing. There is some additional circuitry.
Quoting a data sheet for an IC!?!?!? You probably can't even buy the part in less that 100k piece lots. Hardly a helpful suggestion. Also what about UL and related safety approvals. That is probably a $50-75k fee for submittal.
Banned
Petition one or more of the moderators to have me permanently banned. I promise I won't come back with a new username/e-mail address. :thumbsup:
In the meantime help the OP. . .but. . .Primum non nocere.
If you've taken the Myers Briggs I'm betting the last letter in the sequence is a J. :laughing:
Not that there is anything wrong with that! :whistling2:
What is tripping today? Since you are looking for an RCD device is it that you do not have an RCD today or you have one but it doesn't have an auto reset feature? If the latter is your problem that the existing RCD is tripping? Where is this RCD in your panel? Is it the main breaker or a branch circuit?
"...Reduction of unwanted tripping....that are typically generated by inverters and the main cause of unwanted tripping of residual current devices..."
So maybe it isn't weather related but the high frequency of your solar system inverter is tripping the RCDs. So if you are not home can you disconnect the solar? Surely your load is low when you aren't home. Alternatively maybe the inverter company can sell you a filter to put after the inverted to stop the noise and harmonics from coupling into you power system and tripping the RCDs. Lastly power these sensitive things like refrigerator and fish tank from branch circuits not protected by the RCD so if it trips these items can stay up. I think you have several options instead of a resettable RCD.
Not clear what your problem is so hard to give helpful clues. Also RCDs are not common here (an solar is not plentiful either, however growing) but seem to just be a GFCI of some sort.
1 - 17 of 17 Posts
