Greetings all:
I am a small time landlord and a tenant informed me that the bulbs (lamps) in the kitchen lights fail rapidly - sometimes in as little as 24 hrs. According to her, both CFLs and incandescent bulbs have had a short life. Here are images of 2 of the failed 60w incandescent bulbs that I replaced yesterday. http://i1199.photobucket.com/albums/aa472/Deerfield_rental/Packard/20160105_2317251.jpg http://i1199.photobucket.com/albums/aa472/Deerfield_rental/Packard/20160105_2319121.jpg It looks as if the element vaporized. One bulb has splatter marks on the inside of the glass.
The two fixtures are 7 yrs old (along with the circuit wiring and the breaker box at 7 years since installation). The two fixtures have 2 bulbs apiece. The lamp sockets look as new - no corrosion or signs of overheating. The fixtures themselves are the half dome style that has been popular in the past decade or so. Other lights on the same circuit, including some adjacent recessed cans with BR30s are still the original bulbs that I put in 7 years ago. Both fixtures are on a common pair of 3-way switches. Voltage at the lamp holders was 120.1 to 121.0v. I had the same voltage readings at a nearby receptacle on a different circuit. Each fixture had one bad bulb. One fixture had a bulb that was not lit and that appeared to have smoke swirls on the inside of the glass and when I touched it to remove it, the bulb lit up (and stayed lit). I switched the lights off/on/off 30 times from each switch (I was thinking that maybe there was a bit of a voltage spike from a bad switch).
I have not observed anything incorrect or out of the ordinary. I realize that with off shore manufacturing, that there are some substandard bulbs out there (my experience more so with CFL than incandescent). I installed some new old stock 60w Sylvania bulbs that I picked up at an estate sale (bulbs not made in Asia) and put a slight film of dielectric grease on the threads & center, left the fixture shade off and told the tenant to call me when the bulbs once again fail.
Any ideas or suggestions on what the cause might be? BTW, the same tenant has been in the house for the past 6.5 years so I don't think the tenant's expectations are out of line.
