Hi all,
I posted this in the carpentry thread and then searched for related issues and some of them were re-posted in this section, so I figured I'll re-post it here. If the forum mod feel it aint right pls delete them, willg et you a beer for your extra work :thumbup:
Anyways, this is what I wanted to ask,
I've got a tricky problem, atleast tricky for newbie DIY guy.
We have a GE Profile range, and it has a cook top and microwave with hood, vented to outside wall.
We cook a lot of oily, greasy stuff, so I figured I will get a dedicated range hood as the one in my microwave wasn't that effective.
So I bought a Franke EuroPro 30" hood. Here is the spec and installation pdf link.
http://www.frankeksd.com/specviewer.php?prodid=385
http://www.frankeksd.com/grfx/pdf_fi...EuroProINS.pdf
I removed my microwave, and the cabinet above it. First off I noticed that, Franke hood has the vent hole on top, while the microwave had the vent on the back side. To make it worse, the Franke vent hole is circular (6" dia) while the microwave is rectangular (oval) shaped.
Another issue is, the cabinet was mounted right on the rectangular vent, so if I install the new hood undearneath the cabinet, I wouldnt be able to use the round to rectangle transition.
So, should I remove the drywall, take the existing rectangular vent, add a circular vent tube, increase its height, put vent holes in my cabinet and then connect the hood to it?
What is the best way to attach the Franke hood to the existing vent? Can I use flexible metal duct from Franke to the existing vent or should I replace the existing square vent to a circular one??
Ive got some pictures in the following links, it would be great if any of you can give me a suggestion.
http://img22.imageshack.us/img22/2041/dsc5395.jpg
http://img26.imageshack.us/img26/5521/dsc5399x.jpg
http://img149.imageshack.us/img149/6554/dsc5401.jpg
http://img200.imageshack.us/img200/3827/dsc5402.jpg
http://img91.imageshack.us/img91/1191/planz.jpg
Thanks in advance
Thanks in advance
