I was setting up electrical wiring for the kitchen appliances,
and someone in the forum reminded and now I just realize that there is not enough vertical clearance from the existing stainless steel range hood to the top of the gas range (only 19").
Here's what's in the manufacturer's install note for the gas range:
"24" min. when bottom of wood or metal cabinet is protected by not less than 1/4" flame retardant millboard covered with not less than No. 28 MSG sheet steel, 0.015" stainless steel, .024" aluminum or .020" copper.
30" min. clearance between the top of the cooking platform and the bottom of an unprotected wood or metal cabinet."
It's regular wooden cabinet around w/ the stainless steel range hood under the top center cabinet -- 19" above the top of the gas range. The vent pipe above the range hood is installed inside the top center cabinet.
Question:
So, in this case the wooden cabinet is considered "unprotected"?
There is also this note in the install instructions:
"When installing a cooktop under existing cabinets and the installation does not meet the minimum cabinet clearances, install a range hood above the cooktop to avoid burn hazards."
Question:
This is where I'm not sure -- does this passage imply the existing stainless steel range hood is considered adequate protection even if current clearance is only 19" (obviously less than even the "protected" scenario)? Have I interpreted the passage incorrectly?
Do I need to do anything at this point (e.g. modifying the top center cabinet) to be compliant w/ any safety clearance requirement?
Thx.
Question:
Question:
Thx.
