Just wanted to bounce an idea off everyone.
I am replacing two straight stair treads. The current treads were flush with the risers :huh: and not the prettiest things once I got the carpet off. I need to raise them a bit, too, since the floor above was tiled (and thus raised from original) and I will be adding hardwood below (leaving that floor higher than the existing carpeting).
My idea is to cover the risers and existing tread fronts (painted 1/4-in plywood) and install hardwood treads (hickory) on top of the existing pine treads. Right now, there's some difference between the stair rise but doing that reduces the differences to ~1/4-in stair-to-stair.
I can get under them (full basement) so I was going to use wood screws from below. Thinking countersunk 1-1/2 #8 screws, six per tread.
To keep them from being squeaky, I was going to put 30# tar paper between the old and new treads.
My reasoning:
- someone can replace the treads at a later date without a bunch of hassle
- beating the old treads out looks too much like work (and unnecessary)
Thoughts?
My reasoning:
Thoughts?
