On a concrete front walk that's probably 30 years old, 1 panel has sunk a little (3/4" of an inch?) and water would pool there for a bunch of years now.
I (foolishly??) got the bug in me to fix it.
I dug under the low corner and Using a car jack (1 1/2 ton cap) I lifted it almost level with the panel next to it. (wasn't able to get higher than that - the jack was straining / really hard to pump it up more / afraid I might bend the lever on the jack.
I started realizing - even if I get it level / higher (to allow for settling).... then what? What do I do to keep the panel up / allow for settling. And there;s a gap now between the bottom of the concrete and undisturbed dirt... (yeah, it's just dirt under it? I thought there'd be an inch or 2 of gravel?)
Oh, and how to get the jack out THEN fill the area (taking the jack out = the corner will sink?
Any thoughts on the panel weighing more than 1 1/2 tons? Or is it likely binding against the next panel?
YES, I did look around a while ago for a company that does this work, but no one I found was interested in a small homeowner job like this.
THANKS!
THANKS!
