Raised vanity now slow drain
451 Views 28 Replies 8 Participants Last post by  petervava
I replaced my vanity with a countertop and counter top sink. Previous vanity was 32" high with a drop in sink. My new countertop is 35" inches high. I am going crazy because drain is slow. First tried no overflow sink. Then added vent. Then replaced with sink with overflow thinking pressure from overflow would help. Still slow drain. I snaked drain from wall, perhaps need to do again. Can raising the vanity affect the drainage?
Thanks
Peter V
1 - 20 of 29 Posts
The height of the pipe does not matter. You do know plumbing pipe is sloped to the sewer/septic.
Of that I am aware. This bathroom is on the first floor of a 3 story townhouse with a below grade basement, in the back of the house. Sewer pipes run toward front of house connecting to street sewer via basement. Bathroom with vanity has toilet, shower stall and a tub.
Pardon my ignorance. Plumbing has always been something that has caused me much frustration. I guess you are getting at the point that the highest point is currently the vanity drain. But I thought that there would be a vent for the building drains. Again, am I showing a thorough lack of understanding?
Discussion Starter · #13 ·
There is no obstruction in the piping from the sink to the wall since that is all new (even though it looks old; old parts). The drain doesn't even have a stopper, fully open. The connection into the wall pipe is with those metal covered rubber thangs that don't let the pipes move into each other. I did snake into the wall pipe when I first started this. Perhaps I didn't do a good enough job. Guess I should do a more thorough job as next step.
· retired framer
How well does the tub drain? You would think they connect some where.
Discussion Starter · #16 ·
Hard to say about tub. Was a Jacuzzi that I am in the process of changing to a bigger shower. We hardly ever used it. I never noticed it draining slowly, but with the amount of water in a Jacuzzi it's hard to say. Shower stall which is to the left and toward front of house drains fine.
· retired framer
The tub should take water with the faucet on full with out backing up.
Discussion Starter · #20 ·
1 - 20 of 29 Posts
