We have a finished basement that has an oddly placed sunken floor. The sunken area takes up about half of the room. The way the room is laid out we basically only use the raised side and sort of just walk around the nuisance of a hole. The sunken area is about 10' by 11' with a brick fireplace in the middle. The sunken area has about 8" step down. The fireplace hearth is only about 3 1/2 inches high off the floor.
So what I'd originally wanted to do was raise the fireplace up and put in a wood insert. Then fill the hole with concrete or something. I called a local place that sells fireplaces, but they won't even come out to look at it because they said there is really no way to raise the fireplace up.
I'm now in search of suggestions on what to do and what professionals I should be seeking out. Do I need just a general contractor or do I need a masonry professional, or someone else.
Thoughts on any of this would be greatly appreciated.
Thanks.
Thanks.
