I have a door from my garage to my patio that I would like to raise. We recently removed the patio in order to install a deck. I would like to raise the door to be higher so the deck can be at a more convenient height. I have the space to add a step inside the door, but would rather not have to build a step down into the deck. I have space to go up about 6" if I still need the header, and slightly more if I can modify the header for this.
What would the best approach be for this? I would also like yo make it 36" instead of 32" if possible at this time. I have attached pictures for reference.
· retired framer
You can do a flush header, for a 36" door the header would be 41" long and the same size as you have now .
You would have to put support under the rafters above. cut 41" out of the top plates and put the new header right under the rafters with a new king and jack stud on the left and just a filler block on top of the jack on the right.
ok, so it would be find to remove both top plate boards and have the rafters sit on top of the 2x6 header? I assume that's what your red outline is.
For building out the bottom, I assume I can just frame that like a normal wall to fill the gap?
Thanks for the help so far.
· retired framer
Yes, no different than a deck roof sitting on a beam instead of a wall. Just join the header to the top plates with metal flat straps when done.
