I ran a radon test and found it to be 16 piC/l, four times the level at which they suggest performing mitigation, 4.0 piC/l. I had the crawl space vents blocked. I opened up the vents and retested and it is now 5.5 piC/l, closer to acceptable.
My crawl space is a 4' high over a dirt base. If I remember correct there is a plastic visquine layer under the dirt. There are 4 small vents in the foundation.
When I added the chimney cavity 20 years ago I ran a full length PVC pipe in it from the base of foundation out the top of this chimney chase. It is not connected to anything.
Is there anything I should try before going to the effort of full mitigation? Considering just opening the vents reduced the radon to a 3rd of its previous level, I was thinking some sort of fan in one of the vents pushing air out might make the difference.
