I've got a 100-year-old, 3-story house with a gas boiler, 6 zones, and many radiators. Three on the second floor do not get hot. They probably are in the same zone, but honestly, it's hard to know where all the pipes go.
The boiler is working. All Thermostats are working. Air in the radiators is not the problem. The main feed lines in the crawl space are hot as are the individual feed lines, but not the return pipe from the 'bad radiators. I cannot feel any heat at the base of the 'bad radiators' were the water comes in.
I have hot water in the horizontal feed lines in the crawl space, but not 12 feet up the vertical pipes in the wall.
All my pipes are galvanized steel. Age unknown. I suspect corrosion is the issue and dread replacing pipes in the wall. I see drain plugs on the vertical pipes. Could they save me? Maybe the crude/sludge can be drained/removed there?
Could I drain the 'bad radiators' and ream out the vertical feed pipes? use a cleaning agent?
Yes. I want a quick, easy, cheap, short term fix. If that's not available what should I replace the galvanized pipes with? Pex?
Thanks in advance, Mike
