Ok, so the boiler went out, would not start was an error code 11. Its about 8 years old and we opened the water filter knob under the tank to clean the filter. It wasn't there. So we shut the water supply off and drained the drained the boiler, took out about 1/2 gallon of what looks like muddy water, reinstalled the plug and it fired up for a short time then went back to error code 11. Its a Takagi TK4 IN. We brought a new boiler, same model, installed it and it fired right up but it was making a lot of gurgling noises.
That's the limit of my knowledge. The boiler ran fine but was making a lot of noise, groaning, gurgling, temperature is 140 degrees. GPM reads anywhere from 0.5 to 3, in temp was 58, out was 64. Thermostats (3) are set at 65 and 65 and 67. The 2 gauges at the top are always reading zero. The system is closed type with 3 zones for a concrete slab of 3000sf. The red pumps at the bottom of the picture are the 3 zones, the one furthest left gurgles a lot, the middle one not so much and the right one is quiet. Also same with temperature , left is much hotter than right.
Was told it was a low water issue so we topped off the system and got 10lbs of pressure on the top right gauge by the expansion tank and now it wont fire up at all.
lain:
