Hello everyone.
I have a split level home and the main floor has a full basement under it. The main floor has a large living room and country kitchen. The house is 25 years old. I've always wanted tile in the kitchen but now I have decided to use the tile on the whole level.
This brought me to the discovery of radiant heat flooring. I currently have a heat pump that is on its last legs.
Since I will need concrete board to go under the tile anyway, will this work to also serve as a cover for radiant tubing placed on top of the subfloor? Or will I have to have concrete poured and if so, will that be ok as a subfloor for the tile?
Is the best tile for this job ceramic or can I use porcelain or stone?
I'm kind of trying to figure out if it is more economic to get this tile floor/heating done all at once.
Can anyone tell me how much more expensive it may be to replace my current heat pump with a combination of radiant heating (on the main floor only), heat pump heat on the second floor, and heat pump a/d on all floors?
Thanks for any information you can share!
