Hi, new member here. I am renovating a 25’x20’ guesthouse in a wooded area next to a pond in Wisconsin. So it is a damp climate that ranges maybe from -20 to 110 degrees at the extremes. The floor of the cabin is 10” joists over a 2’ crawl space of dirt. I encapsulated the crawl space the best I could with a heavy plastic vapor barrier, then layed pressure treated plywood across the bottom of the joists to act as a support for foam and had 4” of closed-cell foam sprayed between the joists. My plan was to lay 1/2” pex on top of the spray foam between the joists, then put the subfloor down. My knee jerk thought was to put a reflective foil down between the foam and the pex, but I started to think that there could be risk of condensation between the foil and foam if there is a significant heat gradient. A friend also mentioned the thought of pouring concrete in to act as thermal mass, but that might be a separate question. Thoughts? Thanks people!
retired framer
For condensation you would need a constant supply of warm moist air to come into contact with a cold or cooler surface.
So, which will be the cold surface and where will the air be supplied from.
I would be worried about nailing down a hard wood floor with pex right below.
A friend had a similar system in a house with the pex just attached to the joists a little lower with fiberglass insulation and it seemed to work fine. With out reflective anything.
They glued down the hardwood.
The radiant barrier below the pex would be needed if there was a significant amount of heat loss going down. With 4" of closed cell foam I don't see a lot of heat loss into that crawlspace.
Not sure about your approach of encapsulating the crawl and then isolating it from the conditioned space above. I like to see encapsulated spaces insulated and conditioned.
Will this house be conditioned year round of just occasionally?
Bud
