I pulled a Kohler toilet to check for any leakage and replacee one of the two floor tie down bolts that sheared off some time in the past. So far so good, but I was talked into removing the tank, to make it easier to drop the toilet with new was seal in place. ( minor PITA even with the toilet out and good access to everything, probably due to corroded bolts.)
I got a generic set of bolts and seals from Home Depot, but think I should use the Kohler product. (Single triangular shaped seal with large hole in middlle for tank water and theree grommet type seals for three bolts.)
Questions:
Should I put the tank back on, before setting the toilet in place. Access to the plastic nuts was real bad due to the way the toilet is set in to an alcove, with a stupid tiled shelf just 5 inches above. I am wondering if it was a mistake to remove the tank, even if it will be heavier and more difficult to drop it in place, or if securing it with new bolts should be relatively easy. I can get my hand back there. Those thin screwdriver slots in the heads of the three tank bolts don't help, at least not when the heads are corroded.
Should I just reuse the same Kohler triangular seal? I may not be able to get another as it is Sunday, and it looks fine but rubber rots and I note that one of the three grommet type washers was not inserted though the bolt hole.
Do you have any suggestions or tips, like how to make the new wax seal stick to the bottom of the toilet as I drop it in place. (Other than pushing it on and hoping it sticks to the bottom of the toilet)
Thanks in advance.
Questions:
Thanks in advance.
