1 - 2 of 2 Posts
the Musigician
hi everyone!
the plastic blue outlet boxes say outlet/switch, the gray says only SWITCH, hence i cannot use the gray for outlets? also, can I screw through the plastic with say, a drywall screw into the wall stud to make it tighter than the 2 nails?
tnkx!
DM:whistling2:
Master Electrician
hi everyone!
You can use these boxes for receptacles. Not a problem. Check the cubic inch size - I like larger ones for GFCIs.
tnkx!
DM:whistling2:
That is technically a violation. And the nails hold it plenty tight.
1 - 2 of 2 Posts
