just wanted to check on this detail. (if i already asked this, im sorry. I dont recall this detail.)
I have a 12/3 wire ran in the basement. It was rigged up (before i came here) to have a separate 12/2 line ran off each of the two hot lines in the 12/3. Im going to separate those two 12/2 lines off that and have them run as separate lines back to the panel box instead of this 2 is 1 thing they had going on.
The 12/3 line however is already ran and active. So i figured i could leave it where it is. No point in wasting the wire. The line stops above an old work bench, so i figured i could just attach an outlet to each of the hots and have two outlets on two separate hots.. almost like two dedicated lines. (Maybe it is since it will be connected to a 2 pole 20amp breaker? )
(figured id make each hot have a double gang box with one gfic receptacle and one regular receptacle attached. Since apparently basement lines are supposed to be gfci protected now)
What i wanted to confirm is how to wire the neutral and ground wire form the 12/3 to the outlets. Since there are separate hots, one can go to each outlet. But only 1 neutral and ground in the wire. - I assume i could run the wire into a empty box first and just have each outlet have a white and ground wire running form each and attach to the main wire in that box; nutted up?
Red/black: hot
Pink for white neutral
Green: ground
(both the same, just aligned differently)
Or is there a better way of doing that?
I dont even have plans for those outlets. It just seems a shame to waste what is already there.
Red/black: hot
Green: ground
