I have a good sized place in the Los Angeles area, built in 1979, and which has a 5 ton central air unit. It only gets run for cooling about 3-4 weeks per year as the climate is mild.
Two years ago the original 1979 AC unit died, and I replaced it with a new 13 SEER 5 ton R-22 Rheem outside compressor, indoor cased coil and gas furnace. I did the install myself. I had done some AC work way back while in college and had the necessary tools (gauges, vacuum pump, recovery system, etc). It was a PITA, but worked pretty good. I made sure to install a TXV also and very carefully charged the system.
A couple of weeks ago I did a routine check prior to Summer, and discovered I had no cooling. Checking with the gauges showed essentially no pressure. I pressurized it with gas to about 50 psi, and it leaked down about 10 psi per day. I went over all inside and outside components with a leak detector and found nothing. I double checked any of my brazing I thought could be questionable and it doesn't appear to be leaking.
The original 7/8" x 3/8" 1979 lineset runs under the at-grade slab for about 28', connecting the condenser and evaporator. At this point I'm thinking that must be where the leak is, but don't know of a way to check it, other than by process of elimination. The linset is run far enough in from the edges of the house slab that I can't pick up any trace of leaks at the slab edge.
I'm looking at replacing the below slab lineset with 50' of 7/8" x 3/8" run through the walls and ceilings. It's gonna be an ugly job, so I want to make sure I have everything I need before knocking holes in the walls.
Is there anything special I should do as part of the lineset replacement? I plan on including a new dryer/filter in the liquid line. Do I need to add any oil to the system to replace whatever might remain in the abandoned below-grade lineset? Do I need to be concerned that the system might have sucked in any outside contaminates through the underground leak? While it might be desirable to to increase the suction line size to 1 1/8", the fittings on each end are 7/8", so I'm inclined to stay at 7/8".
Thanks for any advice you might have.
