A few thingsHi,
I'm finishing a basement and adding walls according to an existing floor plan (labeled as wall a and b on the floor plan). These are non-weight bearing walls. I have a few questions on how to frame them.
Each of the two large walls (Wall A and Wall B) images have a door towards the end. If walls need to anchored to the floor within 6" of the end of each bottom plate, I don't know how to anchor the side past the door. Especially on Wall Bb, there is a large closet opening, and then a doorway, and there doesn't seem to be anywhere I could possibly anchor it to the floor. In image Wall B 2, I removed some of the king studs to make room for a two or three gang switch box. I could anchor it to the floor there? But that would be the only anchor to the floor. There woudl be anchors to the ceiling and other existing walls. Does that work?
Also, in image Wall B 2, where I removed the studs to put in a box, does the blocking work there to replace the missing studs?
Anchor is not needed with non bearing walls. You can shoot them down, pin them down with nails or use screws.
Non bearing walls do not need headers just a top sill and cripple studs.
Are the exterior walls built inside the foundation yet?
