1 - 6 of 6 Posts
Hey guys just have a few questions about putting up a western red cadar fence. Im using materials from hoover fence and also have a question our two about there products. Also I live in minneapolis minnesota and this will relate to a question later. Ill posts the questions up and if more info is need Just ask.
  1. I heard cedar should not be installed with cement as this causes premature rot is this true? If it is true then thats fine I have no problem with other solutions.
  2. If cement cant be used will pea gravel provide enough stability provided its buried deep enough? I actually prefer this method so basically just need confirmation from some experts that indeed I can place a 4x4 WRC posts with gravel going around it and it will be enough to keep the fence up :laughing:.
  3. I live in minneapolis will 3 feet provide enough stability to a post thats gonna be 5 feet above ground, and will it be buried enough so the frost does not effect it? If not I can always go deeper.
  4. Hoover fence has something called a OZ post thats is basically a 36 inch anchor that goes into the ground so cement does not have to be used and basically I wanna know if these are strong enough to replace the cement method. (money is not a issue and anything that can help speed me up is always good :thumbsup:)
I appreciate anyone who takes the time to read this and reply and want to say thanks.
If you burry cedar in cement, or anything else that is essentially water tight it's going to rot. I don't know the product your mentioning but if it one of those stakes that you pound into the ground and then slide the post in; they work well but make sure there are holes in the bottom to drain water or it will rot completely out in about 3 years. I speak from experience
1 - 6 of 6 Posts
