Just have some questions about framing in for new stairs to the basement and cutting the hole in the existing floor.
Attached is the framing I'm going to do around the hole after it's cut to put new stairs in. Pardon my horrible MS paint skills
Original joists are 2x6 rough dimensional lumber.
The length of the cut is about 11'6". No cuts have been made yet, and I have a temporary support in place using a 4x4 horizontally under the soon to be cut joists and floor jacks . I'll be cutting away the joist that run across where the stairs will go. From the attachment you can see the joists connect over top of the exterior block wall in the basement. As I understand it normally you would double up on the non cut joists on the to ends and use doubled up boards with hangers to join to the newly double'd up full length joists.
Questions:
1. If I'm using a 2x4 wall to support a double 2x10 header that I will nail the cut joists to using hangers. Do I still need to double up on joists that were not cut on either end? Or am I completely wrong and should re-think this?
2. I'm using plastic sheeting, tuck tape, rigid foam board for insulation and furring strips screwed in to the block with masonry screws (counter sunk into the strips). I plan to use a 2x4 to space the stringers away from the fur strips to leave a gap for drywall and a skirt board. Are the furring strips sufficient to screw the 2x4 and eventually nail the stringer to (the stringer will be properly set in at the hangerboard and bottom?
3. The bottom plate of the framed support wall should be pressure treated lumber correct? I have concrete unfinished floors in the basement. I am assuming the same will go for the board I anchor the bottom of the stairs to?
As always any help is greatly appreciated.
Questions:
