I wasn't sure whether to put this thread in plumbing or insulation, so I picked plumbing.
I have a gas water heater. As you can see I have insulated the hot water pipe with 1" thick polyethylene foam, up to the recommended 6 inches away from the flue pipe. (Please ignore the foil tape below that; that's temporary.) I would like to insulate all the way to the top of the WH because there's a lot of wasted heat emanating from the uninsulated section of pipe. The recommendation I have seen states "single wall metal venting must have 6" clearance to combustible materials." But would it be OK to use UNfaced fiberglass pipe insulation all the way to the WH top, since that isn't combustible? Or perhaps up to but not beyond the edge of the draft hood? The pipe insulation I'm looking at is also 1" thick and is rated up to 1000 degrees. I would secure it with wire. Thanks for your thoughts.
