1 - 12 of 12 Posts
A few years ago, I ran 12/3 to 2 20A outlets using a shared neutral. I'd like to change these outlets to be GFCI, but was wondering if GFCI would work on a shared neutral, or if I could only install a single one and just cap off the other line.
I dont believe GFCIs work on shared neutrals. I ahve tried it and failed.
Maybe a real electrician can chime in though, and offer a solution.
You can put ground fault circuit interrupter units on a multiwire branch circuit wherever you wish to.
But if you want to continue protection from one GFCI receptacle to additional plain receptacles, you need a separate 2 wire cable off of the load terminals of the GFCI receptacle.
Actually, now I remember what I was trying to do was install a GFCI breaker on a shared neutral circuit. <---- This did not work for me.
Discussion Starter #6
I've had trouble with GFCI breakers, as well - especially when the actual load is a long ways away. Not sure why... For instance, an outlet on a lamppost 100-feet from the house never worked.
Thanks for the other responses. I'll put two GFCI's at the end of the 12/3 and then run 12/2 to any other outlets beyond that.
E2 Electrician
Then you had a neutral to ground short, or another neutral related issue. I can assure you right now, the issue was not with the GFCI breaker.
For very long runs beyond a ground fault circuit interrupter, induced currents (due to capacitance) between hot and ground could be sufficient to trip the GFCI.
E2 Electrician
Not that I don't agree with you... But seriously. You want to give me the exact length that this occurs at? The reason I bring it up, is because I've never witnessed this in the field... I use a meggar and always find an insulation break down.
Electrical Contractor
I've seen it.
We did a pool installation with a rather long feeder conduit. Instead of using several GFCI breakers, we installed a big one on the feeder, protecting the entire pool panel from the source.
Nuisance tripping occurred, even with all the loads turned off.
This was a new installation, with THWN wires installed in PVC conduit.
Ended up having to scrap the idea of Ground-fault protection on the feeder, and used individual breakers on each piece of equipment.
Never had another problem after that.
If you put the single large GFCI unit out at the pool house rather than at/in the main panel then I would not expect nuisance tripping.
There was no "pool house" -- DUH ...
Besides, you can NOT back-feed a GFCI breaker and use it as a main in a panel
1 - 12 of 12 Posts
