Hi all.
I have two rooms that share a girder running along the center line of the house. Basically, the joists from each room come to rest on top of the girder, get nailed together, and then get a 13" blocking piece put between each pair.
Because of existing wiring, and because I just bought a framing nailer limited to 3.25" nails, I want to instead put a 14.5" blocking piece between the joists in both rooms just a few inches out from the girder on either side.
Doing it my way will put twice as many blocking pieces, so that should be better, but it will also allow me to shoot the nails in rather than manually hammer 5" nails through two joists into the blocking piece on each side.
Question is, is that allowed, or is there a requirement to block specifically over the girder (made up of three 2x10s nailed together and resting on cinderblock piers).
Thanks.
Thanks.
