1 - 11 of 11 Posts
i carved this sword
im curious if this would work, and if allowed by code, where a beam terminates on a partition wall, is where a joist (2x10)needs to come in like others in that direction, i put a blocking thing spanning across for something to nail to, is that ok? did i do that wrong? the partition wall is 2x4
retired framer
Is the partition wall a load bearing wall down to a foundation?
i carved this sword
Discussion Starter #3
yeah,i got joists on it and a partition wall above it the next floor
retired framer
What you have is fine the blocks are seldom called for over the wall.
More often we would see the join in direction right over the wall especially when there is a wall above it. Changing direction on the floor plywood can be troublesome with lumps and bumps and not so straight cuts. It gets well hidden when it is under the wall. :wink2:
Do you understand the rules on bridging between the joists?
i carved this sword
Discussion Starter #5
not really, but i think when a wall is over or under the bridging is 16 oc but i could be wrong
retired framer
bridging is evenly spaced no more than 7 ft from wall or each other.
So if the span was 13 ft it would be at 6 1/2 ft
if the span was 15 it would be at 5 and 10 ft.
It is never drawn in but there would be a note on the plan. :wink2:
Hammered Thumb
I think this is just theoretical, so nothing will align like that in the field. If it did, I believe it would look more like this:
Beam (blue) min 1.5" bearing, so you don't have enough of the 2x4 wall for the 'aligned' joist (orange) to bear on the wall. So it will have to hanger into a double header (red), which then needs a double joist (green) each side as the header doesn't have enough support on the 2x4 wall below. Also you need blocking (purple) between joists over each bearing point when not connected by a rim joist. Bridging (yellow) max 8'.
retired framer
We only see that solid blocking above a wall when the wall is a stress wall.
Is it in the code?
i carved this sword
Discussion Starter #11
i thought about what I was told, thought "why not change that partition wall to a 2x6 wall instead? giving 2.5 inch for the beam and the double header can sit on the plate", as for bridging i tend to do it in an overbuilding way but i figure it might make the floor that much stronger, i wonder if i still need the bridging over the plate with the butting joist that close and with my bridging bring 4' oc
1 - 11 of 11 Posts
